Coupure en vol M160 fichier données
- persomlt
Venant de recevoir le cordon d'importation des données, voici des infos concernant un vol terminé sans moteur...
J'incriminais un problème de carburant, mais le fichier m'interpèle: que veulent dire les valeurs : 65,124,1,4,0,0,0 qui correspondent au moment où ça a coupé (en fin de montée plein pot)?
Merci de votre aide,
Fabrice
65,124,0,628,118000,996,403
65,124,0,628,117000,976,384
65,124,0,632,116000,960,368
65,124,0,628,110000,760,274
65,124,0,620,101000,611,203
65,124,0,592,87000,596,164
65,124,0,568,82000,596,152
65,124,0,544,79000,596,145
65,124,0,520,76000,596,145
65,124,0,508,76000,596,145
65,124,0,504,76000,588,145
65,124,0,500,76000,584,145
65,124,0,496,75000,588,145
65,124,0,492,75000,588,145
65,124,0,492,75000,592,145
65,124,0,488,74000,623,145
65,124,0,488,74000,745,164
65,124,0,484,86000,1000,239
65,124,0,500,115000,1000,403
65,124,0,524,116000,1000,403
65,124,0,556,116000,1000,403
65,124,0,576,116000,1000,403
65,124,0,584,116000,1000,407
65,124,0,596,116000,1000,411
65,124,1,4,0,0,0
65,124,3,52,0,258,0
65,124,6,52,0,258,0
65,124,0,52,0,258,0
65,124,0,52,0,258,0
65,124,0,52,0,258,0
65,124,0,52,0,258,0
65,124,15,52,0,258,0
65,124,0,52,0,258,0
65,124,0,52,1000,258,0
65,124,0,56,2000,258,0
65,124,0,72,4000,258,0
65,124,0,80,4000,258,0
65,124,4,84,4000,258,0
65,124,0,88,4000,258,0
65,124,0,96,4000,258,0
65,124,21,100,4000,258,78
65,124,0,104,5000,258,58
65,124,0,112,6000,258,54
65,124,5,116,6000,258,54
65,124,0,116,6000,258,54
65,124,0,120,6000,258,54
65,124,0,124,7000,258,54
65,124,0,128,7000,258,54
65,125,0,136,8000,258,54
65,125,0,148,9000,258,54
65,125,0,160,10000,258,54
65,125,0,176,11000,258,54
65,125,0,188,12000,258,54
65,125,0,196,13000,258,54
65,125,0,196,14000,258,54
65,125,0,204,15000,258,54
65,125,0,212,16000,258,54
65,125,0,228,17000,258,54
65,125,0,236,16000,258,54
65,125,0,244,16000,258,54
65,125,0,252,16000,258,54
65,125,0,260,16000,258,58
65,125,0,272,16000,258,58
65,125,0,280,16000,258,58
65,125,0,288,16000,258,58
65,125,0,304,17000,258,58
65,125,0,316,17000,258,62
65,125,0,328,18000,258,62
65,125,0,340,18000,258,62
65,125,0,348,19000,258,62
65,125,0,360,20000,258,66
65,125,0,368,20000,258,66
65,125,0,376,21000,258,66
65,125,0,384,22000,258,66
65,125,0,388,23000,258,66
65,125,0,396,25000,258,70
65,125,0,404,26000,258,70
66,125,0,416,28000,258,70
Fabrice
65,124,1,4,0,0,0
65,124,3,52,0,258,0
65,124,6,52,0,258,0
65,124,0,52,0,258,0
65,124,0,52,0,258,0
65,124,0,52,0,258,0
65,124,0,52,0,258,0
65,124,0,52,0,258,0
- STEPHANE ECOLAN
Re: Coupure en vol M160 fichier données
Bonjour Fabrice
Pour moi, sonde de température HS !
L'enregistrement annonce 1000° juste avant la coupure puis reste bloqué à 258°
Salut.
258 est le signal radio pas la temp...
temp avant coupure= 596
on dirait une rupture de liaison entre ton récepteur et l'ECU!
pas d'autre explication. ...plus d'alimentation électrique. ..plus d'enregistrement var il s'arrête net et repart avec la température bien retombée pour ton démarrage suivant. ..
- STEPHANE ECOLAN
Haaa, autant pour moi !
Donc faux contact dans la prise du RX alors ?
- persomlt
Ok, merci pour l'interprétation...
Depuis, j'ai refait deux points fixes et un vol sans problème...
J'avais mis ma coupure sur le compte d'un problème kéro car il en restait peu dans les réservoirs et j'avais de l'air dans l'UAT; c'était plus rassurant...
Je compte y aller aujourd'hui et vais donc voler haut, déjà que nous sommes un vendredi 13...
Y a t il des consignes vraiment particulières pour le cheminement des cables ECU chez jetmunts?
Fabrice
Fabrice
- Nhalyn
Cheminement, à part éviter tous champs électriques ou magnétiques (donc pompes, moteur, accus), y'a pas vraiment...
Par contre, si c'est un faux contact, il faut que tu regarde ton installation : tes fils sont-ils bien immobilisés en particulier près des branchements ?
Un fil qui bouge dans les accélérations et turbulences sous son propre poids fait des efforts sur les prises qui peuvent ainsi bouger et perturber un écu qui est sensible... Ces capteurs mesures des pouillèmes de volts de variations...
- persomlt
Bon, ben deux vols sans problème et le troisième perturbé par ma commande de roue avant.... Grrrr...
J'ai checké tous mes fils et n'ai rien vu de particulier; le cheminement des fils me semble correct, évitant de passer près de la pompe et étant attachés à des passe cables.
Ah, oui, petit "détail" : J'ai 2 after burner (xicoy) et ils étaient montés avec un Y sur la sortie des gaz du Rx; m'étant souvenu qu'on m'avait rapporté un cas supposé de perturbation, j'ai utilisé pour les brancher une voie libre du Rx + mixage...
La suite au non prochain épisode, lol...
Bons vols à tous!
Fabrice
Bons vols à tous!
Fabrice
- Nicolight
Simplement pour m'instruire, quels sont, dans l'ordre, les parametres affichés dans ce fichier?
(42 LOIRE et 75)
-Rafale sport + merlin 140k
#cycle, page, aux (sert de mot d'état), Temp, RPM, Signal RX, PW pompe
- Nicolight
Merci.
C'est peut etre un peu hors sujet mais tant que ca.
sur mon 11ème vol, j'ai eu un son de "flemme" en vol or je n'ai plus le fumigene. Je ne suis pas certain mais il me semble que c'etait à une remise de gaz progressive.
Je n'ai pas aimé le son, je suis resté en altitude pour analyser le comportement sur quelques hypodromes. Mais ca ne s'est pas reproduit. Pour me rassurer j'ai planté le GSU au posé pour voir s'il pouvait y avoir un message. Bref..certainement plus de peur mais il y a t'il une piste à suivre à mon point? ou est ce que ca arrive simplement parfois?
(42 LOIRE et 75)
