[Vendu] Hawk 100R
loukis
[Vendu] Hawk 100R
Message par loukis »
Excellent condition Hawk 100R turbine.
Reverse flow turbine extremely low fuel consumption, 288 minutes on the ECU
Hawk 100R technical figures
Every engine is delivered with its own unique performance data sheet.
Example of typical data:
Thrust range 0.6 - 11.0 kg / 1.3 - 24.4 lbs +/- 5%
Pressure ratio 1.2 - 3.8
Rpm 60 000 - 175 000 rpm
EGT 390 - 760° (max 800) Celsius
Fuel consumption 30 - 260g / minute
Fuel Kerosene, Jet A1 or Diesel (EN590) with 1.5% oil
Oil quality Two stroke outboard oil
Engine control Fadec full auto start
Starting gas Propane butane mixture
Battery LiPo 7.4, 2000mAh
Mounting Lugs with fuel / propane connectors
Compressor Radial, transonic in-house design
Turbine Radial
Combustor Reverse flow type
Engine weight 1650 gram (engine and starter)
Airborne Install weight Aprox. 2000 gram
All data in ISA conditions.
Unique features for the Hawk 100R
•Unique rotor damping system
•Milled in house designed compressor
•Mounting lugs of solid aluminium with fuel connectors
•Lowest fuel consumption on the market (2,1 liters will last for 10 minutes flying in normal sport / scale aircraft)
•Fast spool times
PRICE: 1600 Euro + postage from Chypre
photo 1 (640x478).jpg (161.79 Kio) Consulté 1350 fois
hawk GSU (640x640).jpg (232.52 Kio) Consulté 1350 fois
hawk2 (640x478).jpg (191.78 Kio) Consulté 1350 fois
loukis
Re: [Vends] Hawk 100R
SOLD :D
Revenir à « Moteurs »
