Russian Sukhoi Su-35 Pilot Ejects For a Hollywood Movie
passagealanglaise
Russian Jet Cabrio Flight
Russian jets without canopy
Those photos are real and were made during the filming of the Russian movie involving jet fighter stunts. In one episode they had to film the jet without a canopy, so rather to film it on the ground they decided to hire a high-class pilot to make a real flight without that glass thing. He had to take off a few times on such plane in order to film enough material to be included in the final footage.
“The maximum speed I achieved on the jet plane without a canopy glass was around two times greater than speed of sound. While on this speed I even managed to pull out my fingers in glove for an inch or two outside – it became heated very fast because of immense friction force plane undergoes with the air.“, writes the pilot.
“Usually such tests were conducted in winter time, so it was deadly cold without a canopy and I was pretty glad when this heating began, counting minutes before the plane would reach enough speed/velocity so that the air around becomes hot enough. But it wasn’t the main problem for me. In my personal rating of the dangers connected with such tests one of the most bad sides was the extreme roar. Because of this extreme roaring you couldn’t hear the radio so you were flying in deaf mode, you were afraid to pull throttle harder just because going faster was meaning going louder.“, he continues.
On the photo above: Russian military pilot Frolov is getting ready for the flight on the jet cabrio. It is pretty freezing outside, but it would be much colder when he would take off.
The plane is being prepared for the no-canopy flight.
A cabrio ride above the sea.
After the take off.
And that’s one more test – the second pilot tests the ejecting system while on the flight with no canopy installed. The first pilot remains in the plane.
And now the flight is over.
Life's too short not to be...
Re: Russian Sukhoi Su-35 Pilot Ejects For a Hollywood Movie
Y a vraiment des gens maboules.....
Il a du se retenir de faire des vagues comme l'été par la fenetre de sa voiture........à Mach2
Et le mec, là, tranquille, te dis que "ouais, quand je passe les doigts dehors à Mach 2, ça chauffe un peu..."
Y'a pas, les Ferrari, à coté de ça, c'est pour les gonzesses...
salut et heureusement que le pilote ejecté est partie vers l'arriére sinon le pilote avant aurais fait le poulet roti :mdr:
l'arriére du cokpit à ramassé lors de l'éjection :cry:
En même temps, quand tu t'éjecte, il n'est pas demandé que l'avion soit réutilisable...
:boulet:
OK, je sors ! Eject ! Eject ! Eject !!!
rider-60
Message par rider-60 »
Y sont pas un peu Marseillais les Russes?
Mach 2 en cabrio je n'y crois pas un instant, meme avec le cockpit vu ce qu'il traine sous les ailes à mon avis il n'y va pas.
J'aime bien la photo de l'ejection, vu la prof de l'avion meme sans les fusées le gars aurait ete ejecté :lol:
quoiqu'il en soit merci pour l'info! ils sont prets à tout pour recuperer un peu de billets verts.....
rider-60
la bande annonce http://www.imdb.com/video/screenplay/vi4272685337/" onclick="window.open(this.href);return false;
ça sent un peu le photoshop quand meme.......
rider-60 a écrit : vu la prof de l'avion meme sans les fusées le gars aurait ete ejecté ....
Ca ne veut rien dire du tout...
Dans cette conf (sans bidon, juste en 6/0/4+), l'avion est largement bisonique...
rider-60
Le SU30 MK est donné pour Mach 1.9 en lisse; et voilà ce que ça donne sans photoshop, effectivement la profondeur plein piqué à vitesse zero ça fait pas grand chose ;) ........ça laisse reveur sur le pouvoir des images et d'internet........
ejection su 30.jpg (18.79 Kio) Consulté 3993 fois
Revenir à « Radio Terrain »
